You can use the XCO command line to replace a faulty device
		with a new device and maintain the configuration of the old device.
				- Ensure that periodic
					configuration backup is enabled on all devices that may need RMA. This
					prerequisite ensures that you have the latest configuration file to be used for
					recovery.
- Ensure that maintenance mode is
					enabled upon reboot on all devices.
You can replace the following SLX devices with the Extreme devices:
				- SLX 9250 with Extreme 8720
- SLX 9150 with Extreme 8520
- SLX 9740 with Extreme 8820
This procedure describes how to replace a
			faulty device as part of the Return Material Authorization (RMA) process. For more
			information, see Return Material Authorization.
				Obtain the configuration backup
					of the old device.
					# efa inventory config-backup execute --ip <ip-addr>
 This step generates a configuration backup ID that you use in step
					5.
				Replace the faulty device with
					the new device.
				Ensure that the ports of the new device are administratively up and
					online.
				The ports on the new device must have the
					same connections as the old device. For example, if the old device Ethernet
					port1 and port2 went to port3 and port4 of another device, the new replacement
					device must have these exact same Ethernet port connections.
				Configure the new device with the same management IP address and credentials as
					the old device.
				Start the RMA process.
					# efa inventory rma execute --ip <ip-addr> --config-backup-id <id>
					 Note    As a best practice, run the command with
						the  --config-backup-id <id> option so that the configuration
						is properly restored. If you run the command without the backup ID, you must
						manually update the configuration on the new device.
				View the RMA history and
					detail.
					# efa inventory rma history -–ip <ip-addr>
# efa inventory rma detail –uuid <uuid>
				View the drift reconcile history
					and detail.
					# efa inventory drift-reconcile history -–device-ip <ip-addr>
# efa inventory drift-reconcile detail –-uuid <uuid>
				Install the HTTPS or OAuth2 certificate on the new device.
					# efa certificates device install --ips <device-ip-addr> --certType [https|token]
- Optional:
				Delete the RMA record.
					# efa inventory rma delete -–ip <ip-addr>
- Optional:
				Manually start the drift
					reconcile process if the RMA process fails during the drift reconcile stage.
					# efa inventory drift-reconcile execute --ip <ip-addr> –-reconcile
